Hi there
I recently downloaded two Sentinel-2 images from what I suspect will be the main repository for downloading of all the ESA Copernicus imagery (https://scihub.copernicus.eu/dhus/#/home ).
Then, using Pro 1.2 Beta, I created a blank Mosaic Datsest and selected "None" under product definition. Then when I tried adding rasters (my two Sentinel images - 6GB each), I used the Raster Type as Sentinel-2. The tool runs but no imagery is added.
The tool error message says:
"2016-02-28T06:31:15.996: Error: 80042019: Could not build mosaic dataset item. [ID: 1, URI: 'C:\GISfiles\Satellite\Sentinel\2015\S2A_OPER_PRD_MSIL1C_PDMC_20151216T185827_R092_V20151216T081004_20151216T081004.SAFE\S2A_OPER_MTD_SAFL1C_PDMC_20151216T185827_R092_V20151216T081004_20151216T081004.xml|Multispectral (10m)']
2016-02-28T06:31:15.997: Error: 8004203f: Could not open source as a raster dataset.
2016-02-28T06:31:15.998: Error: 80040213: Failed to open raster dataset
2016-02-28T06:31:16.035: Error: 80042019: Could not build mosaic dataset item. [ID: 2, URI: 'C:\GISfiles\Satellite\Sentinel\2015\S2A_OPER_PRD_MSIL1C_PDMC_20151219T151201_R135_V20151219T082024_20151219T082024.SAFE\S2A_OPER_MTD_SAFL1C_PDMC_20151219T151201_R135_V20151219T082024_20151219T082024.xml|Multispectral (10m)']
2016-02-28T06:31:16.036: Error: 8004203f: Could not open source as a raster dataset.
2016-02-28T06:31:16.037: Error: 80040213: Failed to open raster dataset
2016-02-28T06:31:16.044: Error: 8004205e: 2 mosaic dataset items could not be built.
2016-02-28T06:31:16.045: Removing invalid mosaic dataset items
2016-02-28T06:31:16.150: Removed 2 mosaic dataset items and 0 unreferenced raster type instances.
2016-02-28T06:31:16.456: Removing broken mosaic dataset items.
2016-02-28T06:31:16.493: Removed 0 mosaic dataset items and 0 unreferenced raster type instances.
2016-02-28T06:31:16.782: Completed synchronization: 2 items selected, 0 items synchronized."
Have the ESA changed the image specifications from what Esri were anticipating when they added the new Sentinel raster type to Pro and 10.4 or is the fault mine?
Regards
Mervyn
