From ArcGIS Pro 3.1, I am trying to use the Extract Multi Values for Points GP tool to extract NDVI values for 75 point records from imagery hosted on the Living Atlas.
The tool fails with a waring message " ERROR 001268: Input rasters: The input item, 29707059, is invalid."
I tried using the Sentinel-2 Views, Sentinel-2 Views Level-2a, Landsat 8-9 Views, always with the same error. I then tried clipping the imagery using the Clip Raster Function, but that still failed. I then tried Make Image Server Layer, and that failed. I even tried selecting the relevant tile from the imager service and adding as a stand alone layer to contents pane, but that also failed.
It really seems strange that I am unable to use these valuable image services to extract values. Am I doing something wrong? Is there a different approach to try? Or is this just not possible?
Right now I am forced to download a 1.03 GB image from the Copernicus Open Access Hub to extract these values for 75 points coveringa small area. Surely there must be a more efficient approach?
Thank you.
