Hi. Geoprocesing show error when train Deep learning model.
Error:
File "c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx\TrainDeepLearningModel.tool\tool.script.execute.py", line 296, in execute
data_bunch = prepare_data(in_folders, working_dir=out_folder, **prepare_data_kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\learn\_data.py", line 1930, in prepare_data
.label_from_func(get_y_func)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\fastai\data_block.py", line 479, in _inner
self.train = ft(*args, from_item_lists=True, **kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\fastai\data_block.py", line 303, in label_from_func
return self._label_from_list([func(o) for o in self.items], label_cls=label_cls, **kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\fastai\data_block.py", line 303, in <listcomp>
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\learn\_data.py", line 315, in _get_bbox_lbls
label_file, class_mapping, height_width, dataset_type=dataset_type
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\learn\_data.py", line 266, in _get_bbox_classes
float(bnd_box.find("xmin").text),
ValueError: could not convert string to float: '144,92'
During handling of the above exception, another exception occurred:
File "c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx\TrainDeepLearningModel.tool\tool.script.execute.py", line 378, in <module>
execute()
File "c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx\TrainDeepLearningModel.tool\tool.script.execute.py", line 372, in execute
del data_bunch
UnboundLocalError: local variable 'data_bunch' referenced before assignment
Are you using a comma for the decimal separator? If so, it appears not to be able to handle regionalized settings.
Thank a lot. I changed windows regional settings and now everything ok
Hello @MārisNitcis ,
Can you please elaborate on what regional settings were changed to fix the issue?
Aniket D
US regional settings. You must make sure that decimals are separated by a dot and not a comma.
I am just following this conversation. When I used the detect object using deep learning using self created training sample. I got the following result that is 100 percent incorrect. I am not sure there must be something wrong while creating the training sample. for building footprints, would there be only one class while labelling the sample under image classification tab?
