How to open/see bundle files with ArcGIS Desktop or whatever?
10276
19
04-06-2017 04:51 PM
MarkMindlin
I tried using the "Open" button and the "Add Data"  button and navigating to my .bundle files in ArcMap, but neither of these recognizes .bundles files.
Any help please.
MarkMindlin
We found the way - Export Tile Cache with parameter "Storage format" - "EXPLODED"
DanPatterson_Retired
where did you get it? the file format is associate with a variety of things including GitHub and stuff for mac's
MarkMindlin
I create a tile cache and try to open/see an individual bundle.
CodyBenkelman
Mark
You can drop the complete cache into ArcMap or ArcGIS Pro  - in this screenshot it would be called "TestCacheAspectRGB".  If you're navigating down into the subfolders and seeking to display individual bundles at different levels, I don't believe we have a method for viewing single bundles.   If that's what you're seeking, let me know and I'll double check.
Cody B.
MarkMindlin
Thank you for your response Cody,
I use a storage format "esriMapCacheStorageModeCompactV2"
Any try to drop any file or any folder (Root OR Layers OR _alllayers OR L(evel)X) I have the error
MarkMindlin
ArcMap 10.3.1
I don't suppose it would be this type of tile cache (never use them... just going by help)
JayantaPoddar
MVP Esteemed Contributor
Do you see any data in the corresponding folder in ArcCatalog? Any data that you can add to ArcMap should be visible in ArcMap.
Also I think the bundle files are a part of the Cache (Tile) folder. If you have access, try working with the entire cache folder.
Think Location
MarkMindlin
Thank you, Jayanta.
I see the image
My question is how to view/preview the content with Desktop or whatever
JayantaPoddar
If the item is not opening in ArcMap by drag-and-drop from ArcCatalog, try previewing it in ArcCatalog. Open ArcCatalog Window (not the one attached with ArcMap).
Select the desired item and Preview "Geography".
Does it display anything?
Think Location
