XArrrayToRaster fails with projection error
386
03-15-2023 02:21 PM
DavidAnderson_1701
I'm using ArcGIS Pro 3.0.3.
I'm doing some raster processing where I need functionality that the Arcgis tools don't provide.   The data is a multidimensional raster.   I thought XArray would be a good way to handle this.  The conversion from raster to xarray worked fine. The xarray processing produced the desired results.   The conversion back to raster is failing with a message about projection.  To test things out I tried a simple in and out on the same data which failed.
import arcpy
temp_max_file = r"D:\r3_analyst_work\Climate_Change_Modeling\climate_envelope\GridMetData_2020\tmmx_2020.nc"
test_rast = arcpy.Raster(temp_max_file,True)
test_rast_xr = arcpy.ia.RasterToXarray(test_rast)
out_rast = arcpy.ia.XarrayToRaster(test_rast_xr)
This produces the following message:
RuntimeError                              Traceback (most recent call last)
In  [144]:
Line 1:     out_rast = arcpy.ia.XarrayToRaster(test_rast_xr)
File C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\ia\RasterToXarray.py, in XarrayToRaster:
Line 377:   arcpy.DefineProjection_management(myraster, srs_stand)
File C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py, in DefineProjection:
Line 13701: raise e
Line 13698: retval = convertArcObjectToPythonObject(gp.DefineProjection_management(*gp_fixargs((in_dataset, coor_system), True)))
File C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py, in <lambda>:
Line 512:   return lambda *args: val(*gp_fixargs(args, True))
RuntimeError: Unspecified error
ShaunWalbridge
We can reproduce this issue, and have logged an issue to address it in the next release.
ShaunWalbridge
The issue has been addressed, and will be fixed in the upcoming Pro release.
