I am trying to connect a query from a widget (widget-select) under WebApp Builder with a geotraitement service (widget-geoprocessing).
The source web service and the geoprocessing service are from ArcGIS Server.
I have two questions:
1) The widget select documentation has these parameters. (attachment 'ArcGIS documentation'). However, I do not have this possibility. (attachment 'my settings'). I don't have 'Set as Input of Geoprocessing'.
2) What parameters should I indicate in the script to retrieve the query from widget-select?
Thank you for your help
