Schedule Model Builder task
308
07-27-2023 12:57 AM
JFloresD
I have a Model Builder model in which an update of the records of two entity classes coming from an entity service stored in ArcGIS Online is carried out.
After validating the model, it runs correctly manually. The problem comes when trying to schedule the task to run at a certain time getting the following error: ERROR 000732: the dataset does not exist or is not supported.
After several tests, I finally get the generic error ERROR 999999.
In no case I have been able to run the model through a scheduled task.
Any idea why it might be failing?
Has anyone experienced this behavior?
RhettZufelt
MVP Frequent Contributor
Often this is caused by trying to access data from a mapped path (other than drives local to the computer).
When logged on, it sets the paths for users.  When running as scheduled task (and not logged in), does not have access to the mapped drives, so will not find the dataset(s).
R_
