I have a python script that geocodes a SQL Server view (not a geodatabase) where all database elements are available through the database connection. As per company policy this is no longer allowed and select only access to just the view is now available. I can see all the tabular records in the view in ArcCatalog when using the new database connection, but the geocode table processing no longer generates geocoded points (Just an empty feature class).
Does anyone know what other access would be needed in order for the geocode table process to run again?
Do I also need access to the base tables that the view is comprised of?
