Can I label a points layer perpendicular to a line layer?
2903
15
04-30-2018 05:08 AM
PaulWirth
I have a points layer (Electrical Transmission structures) and a Transmission line layer. The points layer sits on top of the line layer and because the line layer changes direction all the time it is hard to label the points layer sometimes. What I would like to do is label the points layer perpendicular to the line layer.
Does anyone have an answer for me?
XanderBakker
Esri Esteemed Contributor
It would be important to know what software you are using (and the version).  Are you using desktop (Pro or ArcMap) or ArcGIS Online?
In case of Desktop, you could create a script to generate a field with the rotation based on the bisector. A few years ago I created a tool to define service areas of transmission tower applying the rotation based on the bisector (the green polygons in the image below):
The rotation determined by the tool could be written to the transmission towers and those can be used to define the rotation of the label. See the code below. The angles are determined on lines 51, 73 and 93.
import arcpy
def main():
    import os
    arcpy.env.overwriteOutput = True
    # input fc
    fc = arcpy.GetParameterAsText(0)  # r'C:\...\data.gdb\Torres'
    fld_label = arcpy.GetParameterAsText(1)  # 'LABEL'
    fld_orden = arcpy.GetParameterAsText(2)  # 'orden'
    buf = arcpy.GetParameter(3)  # 20m servidumbre
    fc_out = arcpy.GetParameterAsText(4)  # poligonos de servidumbre
    # spatial reference
    sr = arcpy.Describe(fc).spatialReference
    # dicts, listado para orden
    arcpy.AddMessage('Generar dictionarios con coordenadas, labels y orden...')
    flds = (fld_orden, 'SHAPE@')
    dct_crds = {r[0]: r[1] for r in arcpy.da.SearchCursor(fc, flds)}
    flds = (fld_orden, fld_label)
    dct_lbl = {r[0]: r[1] for r in arcpy.da.SearchCursor(fc, flds)}
    # create list of points and order list
    arcpy.AddMessage('Ordenar torres...')
    lst_ptgs = [pntg for orden, pntg in sorted(dct_crds.items())]
    lst_orden = sorted(dct_crds.keys())
    # create output featureclass
    arcpy.AddMessage('Crear featureclass de salida...')
    ws, fc_name = os.path.split(fc_out)
    arcpy.CreateFeatureclass_management(ws, fc_name, "POLYGON", None, None, None, sr)
    # add fields
    arcpy.AddField_management(fc_out, fld_label, "TEXT", None, None, 50)
    flds_out = ('SHAPE@', fld_label)
    # empty lists for output features
    lst_puntos = []
    lst_lineas = []
    lst_poligonos = []
    # start insert cursor
    arcpy.AddMessage('Recorrer torres...')
    with arcpy.da.InsertCursor(fc_out, flds_out) as curs:
        # first polygon
        if len(lst_ptgs) >= 2:
            pntg_1 = lst_ptgs[0]
            pntg_2 = lst_ptgs[1]
            angle_12 = getAngle(pntg_1, pntg_2)
            cut_line = createPerpendicularCutLine(pntg_1, angle_12, buf, sr)
            # create polygon
            polygon = createServidumbre(pntg_1, cut_line, buf, sr)
            # generate and insert output row
            lbl1 = dct_lbl[lst_orden[0]]
            arcpy.AddMessage(' - procesar: {0}'.format(lbl1))
            curs.insertRow((polygon, lbl1, ))
        # intermediate polygons
        for i in range(1, len(lst_ptgs) - 1):
            # read points
            pntg_a = lst_ptgs[i - 1]
            pntg_1 = lst_ptgs[i]
            pntg_2 = lst_ptgs[i + 1]
            # get angles and bearings
            angle_1a = getAngle(pntg_1, pntg_a)
            bearing_l = (angle_1a + angle_12) / 2.0
            # create cut lines
            cut_line = createCutLine(pntg_1, bearing_l, buf, sr)
            # cut polygon
            lbl1 = dct_lbl[lst_orden[i]]
        # last polygon
            pntg_1 = lst_ptgs[len(lst_ptgs) - 2]
            pntg_2 = lst_ptgs[len(lst_ptgs) - 1]
            angle_21 = getAngle(pntg_2, pntg_1)
            cut_line = createPerpendicularCutLine(pntg_2, angle_21, buf, sr)
            # cut polygon
            polygon = createServidumbre(pntg_2, cut_line, buf, sr)
            lbl1 = dct_lbl[lst_orden[len(lst_ptgs) - 2]]
    arcpy.AddMessage('Listo...')
def createServidumbre(pntg, cut_line, servidumbre, sr):
    Create rectangle using the cutline
    and the size of the servidumbre
    angle_cut_line = getAngleLine(cut_line)
    tmp_pntg1 = pntg.pointFromAngleAndDistance(angle_cut_line, servidumbre / 2.0, 'PLANAR')
    tmp_pntg2 = pntg.pointFromAngleAndDistance(angle_cut_line + 180, servidumbre / 2.0, 'PLANAR')
    # create corner points
    pntg1a = tmp_pntg1.pointFromAngleAndDistance(angle_cut_line - 90, servidumbre / 2.0, 'PLANAR')
    pntg1b = tmp_pntg1.pointFromAngleAndDistance(angle_cut_line + 90, servidumbre / 2.0, 'PLANAR')
    pntg2a = tmp_pntg2.pointFromAngleAndDistance(angle_cut_line + 90, servidumbre / 2.0, 'PLANAR')
    pntg2b = tmp_pntg2.pointFromAngleAndDistance(angle_cut_line - 90, servidumbre / 2.0, 'PLANAR')
    polygon = arcpy.Polygon(arcpy.Array([pntg1a.firstPoint, pntg1b.firstPoint,
        pntg2a.firstPoint, pntg2b.firstPoint, pntg1a.firstPoint]), sr)
    return polygon
def getAngleLine(line):
    pntg1 = arcpy.PointGeometry(line.firstPoint, line.spatialReference)
    pntg2 = arcpy.PointGeometry(line.lastPoint, line.spatialReference)
    return getAngle(pntg1, pntg2)
def createPerpendicularCutLine(pntg, angle, dist, sr):
    pntg_cut_1 = pntg.pointFromAngleAndDistance(angle - 90, dist * 2.0, 'PLANAR')
    pntg_cut_2 = pntg.pointFromAngleAndDistance(angle + 90, dist * 2.0, 'PLANAR')
    cut_line = arcpy.Polyline(arcpy.Array([pntg_cut_1.firstPoint, pntg_cut_2.firstPoint]), sr)
    return cut_line
def createCutLine(pntg, bearing1, buf, sr):
    bearing2 = bearing1 + 180
    pntg_cut_1 = pntg.pointFromAngleAndDistance(bearing1, buf * 10.0, 'PLANAR')
    pntg_cut_2 = pntg.pointFromAngleAndDistance(bearing2, buf * 10.0, 'PLANAR')
    return cut_line
def createLine(pntg1, pntg2, sr):
    return arcpy.Polyline(arcpy.Array([pntg1.firstPoint, pntg2.firstPoint]), sr)
def getAngle(pntg1, pntg2):
    return pntg1.angleAndDistanceTo(pntg2, method='PLANAR')[0]
if __name__ == '__main__':
    main()
XanderBakker
import arcpy
def main():
    import os
    # input fc
    # spatial reference
    # add fields
    lst_puntos = []
    lst_lineas = []
    lst_poligonos = []
        # first polygon
            # create polygon
            # read points
            # create cut lines
            # cut polygon
        # last polygon
            # cut polygon
    return polygon
    return cut_line
    return cut_line
    main()
PaulWirth
Desktop 10.5.1 or ArcGIS Pro 2.1.1
I am not a big time programmer.
XanderBakker
Is it possible for you to share a sample of the data? I could have a look if I can adjust the script to what you need. The result would be an additional field with the rotation in the point layer.
PaulWirth
I have to look into it, but it might be possible. Which layer do you want? Points or Lines.
XanderBakker
It could (or should) be both. Or if the points follow the order (sequence) of the line one could determine the angles of the lines based on only the points. Otherwise, one has to determine the angles of both line parts based on the line. It also matter is the line is a single line, or each segment from tower to tower is a feature. Would be could to see the data to understand those aspects, since it determines how the code should be changed.
GIS_Rookie
New Contributor II
Hi, @XanderBakker !
Could I get a help with this script?
I have the same queastion as @Paul  😕
Never stop learning
XanderBakker
Hi @GIS_Rookie ,
Then I suppose I have to reply with a question similar to the one I asked Paul. Do you have a sample of data that you can share? That will help understand what you have and what you are looking for.
XanderBakker
Hi @GIS_Rookie ,
Thanks for sharing the sample of data. There are a couple of ways you can proceed. I created a line featureclass using the cut lines and changed it a bit to have it align to the left and I included the pole information for labeling. Have a look at the result below:
See below the Python code I used (in the Python window of ArcGIS Pro):
    return cut_line
    pntg_cut_1 = pntg.pointFromAngleAndDistance(bearing1, buf * 1.5, 'PLANAR')
    pntg_cut_2 = pntg.pointFromAngleAndDistance(bearing2, buf * 0, 'PLANAR')
    return cut_line
import os
# input fc
fc = r'D:\GeoNet\TransmissionLabel\point.shp'
fld_label = 'Pole'
fld_orden = 'Pole'
buf = 20
fc_out = r'D:\GeoNet\TransmissionLabel\cutline02.shp'
# spatial reference
arcpy.CreateFeatureclass_management(ws, fc_name, "POLYLINE", None, None, None, sr)
# add fields
lst_puntos = []
lst_lineas = []
lst_polylines = []
    # first polygon
        curs.insertRow((cut_line, lbl1, ))
        # read points
        # create cut lines
    # last polygon
The other way would be to write the angle to the points. This can be achieved like this:
import os
# input fc
fld_label = 'Pole'
fld_orden = 'Pole'
fld_angle = 'ANGLE2'
buf = 20
# spatial reference
dct_res = {}
# first polygon
    angle_12 = getAngle(pntg_1, pntg_2) + 90.0
    dct_res[lbl1] = angle_12
    # read points
    dct_res[lbl1] = bearing_l
# last polygon
    angle_21 = getAngle(pntg_2, pntg_1) - 90.0
    dct_res[lbl1] = angle_21
flds_out = (fld_label, fld_angle)
with arcpy.da.UpdateCursor(fc, flds_out) as curs:
    for row in curs:
        lbl = row[0]
        if lbl in dct_res:
            angle = dct_res[lbl]
        else:
            pass
            # angle = 400
        curs.updateRow((lbl, angle, ))
GIS_Rookie
New Contributor II
Oh, thank you for quick response 🙂
Second script worked well for me, but I have one queastion about ANGLE2. Is there a way to get positive angle not negative? Example in picture, marked with red.
Never stop learning
