Note: This message is cross-posted on Stack Exchange (Export Page Layout to PDF using ESRI add-in with vb.net - Geographic Information Systems Stack Excha... )
I have been trying to convert a vba script to vb.net but I have hit a roadblock and am hoping someone can help me figure out the problem. I want to export the Page Layout of my map to a PDF using an add-in button. The roadblock occurs where I define my PDFCreate class. I keep receiving the error message: "Unable to cast object of type 'CreatePDF_2.PDFCreate' to type ESRI.ArcGIS.Output.IExport". I suspect the error is in my definition and relationship of the document, active view and page layout. I have looked at examples and tried different definitions and procedures but I have been unable to figure out how to fix the problem.
I am using Visual Studio 2010 Professional and ArcMap 10.2.2
Any assistance will be appreciated. Thanks.
Tiffany
Imports ESRI.ArcGIS.Carto
Imports ESRI.ArcGIS.esriSystem
Imports ESRI.ArcGIS.Geometry
Imports ESRI.ArcGIS.Output
Imports System.Windows.Forms
Imports ESRI.ArcGIS.ArcMapUI
Public Class PDFCreate
Inherits ESRI.ArcGIS.Desktop.AddIns.Button
Public Sub New()
End Sub
Protected Overrides Sub OnClick()
PDFCreatemodule()
End Sub
Protected Overrides Sub OnUpdate()
Enabled = My.ArcMap.Application IsNot Nothing
End Sub
Public Sub PDFCreatemodule()
' TODO: Sample code showing how to access button host
Dim pMxDoc As IMxDocument
Dim pActiveView As IActiveView
Dim pPageLayout As IPageLayout
Dim pExport As ESRI.ArcGIS.Output.IExport
Dim pExportpdf As ESRI.ArcGIS.Output.IExportPDF
Dim pPixelEnv As IEnvelope
Dim lDPI As Long
Dim tExpRect As tagRECT
Dim hDC As Long
'pMxApp = Application
pMxDoc = My.ArcMap.Application.Document
pActiveView = pMxDoc.PageLayout
pPageLayout = pMxDoc.PageLayout
pActiveView = pPageLayout
pExport = New PDFCreate
pExportpdf = pExport
pPixelEnv = New Envelope
pExport.ExportFileName = " " & ".pdf"
pExport.Resolution = lDPI
pExportpdf.EmbedFonts = True
pPixelEnv.PutCoords(0, 0, lDPI * PageExtent(pPageLayout).UpperRight.X, _
lDPI * PageExtent(pPageLayout).UpperRight.Y)
pExport.PixelBounds = pPixelEnv
' (device coordinates origin is upper left, ypositive is down)
tExpRect.left = pExport.PixelBounds.LowerLeft.X
tExpRect.bottom = pExport.PixelBounds.UpperRight.Y
tExpRect.right = pExport.PixelBounds.UpperRight.X
tExpRect.top = pExport.PixelBounds.LowerLeft.Y
hDC = pExport.StartExporting
pActiveView.Output(hDC, lDPI, tExpRect, Nothing, Nothing)
System.Windows.Forms.Application.DoEvents()
pExport.FinishExporting()
End Sub
Public Function PageExtent(pPageLayout) As IEnvelope
Dim dWidth As Double, dHeight As Double
pPageLayout.Page.QuerySize(dWidth, dHeight)
Dim pEnv As IEnvelope
pEnv = New Envelope
pEnv.PutCoords(0.0#, 0.0#, dWidth, dHeight)
PageExtent = pEnv
End Function
End Class
Solved! Go to Solution.
No responses here but just in case this helps someone out in the future, here is the now working code.
Public Class PDFCreation
PDFModule()
End Sub
End Sub
Public Sub PDFModule()
Dim pExport As IExport
Dim lDPI As Long
Dim hDC As Long
Dim res = 96
pExport = New ESRI.ArcGIS.Output.ExportPDF
lDPI = 300
tExpRect.left = 0
tExpRect.top = 0
tExpRect.bottom = My.ArcMap.Document.ActiveView.ExportFrame.bottom * (lDPI / res)
tExpRect.right = My.ArcMap.Document.ActiveView.ExportFrame.right * (lDPI / res)
pPixelEnv.PutCoords(tExpRect.left, tExpRect.top, tExpRect.right, tExpRect.bottom)
Dim pdfName As String = ""
Dim saveFileDialog1 As New SaveFileDialog
saveFileDialog1.Filter = "PDF File|*.pdf"
saveFileDialog1.Title = "Save A PDF File"
saveFileDialog1.FileName = pdfName
saveFileDialog1.ShowDialog()
pExport.ExportFileName = saveFileDialog1.FileName
MessageBox.Show("Finished Exporting Map")
pExport.Cleanup()
End Sub
End Class
PDFModule()
End Sub
End Sub
Dim lDPI As Long
Dim hDC As Long
Dim res = 96
lDPI = 300
tExpRect.left = 0
tExpRect.top = 0
pExport.Cleanup()
End Sub
End Class
