So I have an old school tabbed map series as a product for a client with dashboards embedded into each tab. This has worked in the past however the dashboards are shared to a group but the authentication does not carry through meaning it requires a sign in to view each tab. Is there a fix for this?.
My immediate thought was that I used a dev dashboard json and replace the staging version json within the dashboard using arcgis online assistant. The dev app was shared to a different group and so I wondered if that was causing the issues?
If someone has experience this or has a work around please let me know.
