Issue on Getting Count of Intersect in Arccade Attribute Rule
394
5
04-03-2023 03:43 PM
MarcoMob
Having  two feature classes in SDE geodatabase like
-  EGDB.North.Parcels
-  EGDB.North.ProjectsInvest
I am trying to get the total count of Intersection between  EGDB.North.Projects in EGDB.North.ProjectsInvest using Attribute rules like this
 var intersects = Intersects(FeatureSetByName($datastore, "EGDB.North.Parcels"), Geometry($feature)); return Count(intersects) ;
but I am getting this error
002717: Invalid Arcade expression
if(Count(intersects)>0){
  return Count(intersects);
else{
  return 0;
TedHoward2
Using reserved function names as the name of a variable is a bad idea. Try using "var inter =" instead.
Also, you do not need to use fully qualified names for FeatureSetByName. Just use "Parcels".
MarcoMob
Thanks for reply Ted but nothing changed!
var inters = Intersects(FeatureSetByName($datastore, "Parcels"), Geometry($feature));
return Count(inters) ;
still getting same error message
TedHoward2
That looks valid.
You could try exporting those features classes to FGDB or MGDB to see if the problem is specific to SDE.
MarcoMob
Well, this is weird
As you recommended I copied both
into a local FGDB and this is working now
So, why this is happening in SDE? how can I fix this? Is there any solution for this? Thanks
TedHoward2
I believe this is the same issue found here
https://community.esri.com/t5/attribute-rules-questions/attribute-rule-not-working-anymore-in-3-1/td...
I recommend contacting Tech support for a way forward
