Hi Josh
Thanks for your reply - I was not aware of these hidden properties.
Still, I couldn't reproduce your solution or I do not understand what I'm doing wrong that it doesn't work for me 🙂
Can you send me the "style file" from the style editor or share the tile service / style so i can take a closer look at differences?
Im still confused because if I use a simple line feature and set the "dasheffect" to e.g. "9,3,3,3", Cap=Butt, Join = Round and then push that to a VectorTilePackage via "Create Vector Tile Package" the 9,3,3,3 pattern seems to be missing.
If I extract the styles\root.json from the VectorTilePackage (vtpk) I'll find the "line-dasharray":[6,2] and "line-width":2 , although originally it was set to 9,3,3,3 and w/ 1.5.
If I edit the style file manually (line-dasharray to 9,3,3,3 and linecolor to ff00ff) and package again to vtpk, add the vtpk to ArcGIS Pro -> no "line-dasharray" change… but the color is updated.
The same goes for the LineFeature, published as vectortile-service to ArcGIS Enterprise Portal (10.8.1):
The Dasharray is not displayed, if i open the style in the styleeditor I encounter the Dasharray 6-2, although it was published from ArcGIS Pro 2.8.1 as Dasharray: 9,3,3,3.
If I change the Dasharray in the Style Editor to 9,3,3,3 nothing seems to happen.
Even if I download the style and change the properties "line-cap" and "line-join" and update the style on the portal, nothing seems to change.
Portal 10.8.1 MapViewer | VectorTileStyleEditor Dash Array | Modified Dash Array |
What am I missing?
Kind regards
Andi
