Question about Bulk Associations
215
10-30-2024 02:06 PM
TSmith
Hey ya'll-
Got a question regarding a workflow for bulk adding associations. I know the Asset Package tools allow for associations to be created prior to implementing the UN. In our case, we have a lot of service connections in an existing UN that we would like to add junction-junction associations to with associated service meters.
To me- this seems like an FME/Data Interop solution, however I am not 100% sure how to go about creating associations through that tool. Another option would be to iterate by parcel and somehow script this out, if the add associations is a scriptable command within python API or not.
Curious to see if anyone else has done this workflow and what the preferred route would be. Thanks in advance!
RobertKrisher
To bulk load associations into a utility network after the fact you need to use the Import Associations tool. The tool takes a CSV with the global ids and layer information for each feature you want to associate. You can create this CSV using something like python or FME/Data Interop, whichever you're most comfortable with.
RobertKrisher
