Data source errors for layers (Point Errors, Line Errors and Polygon Erros) in Electric Utility Network Map from the Electric Utility Network Foundation v3.4 solution
729
08-09-2020 03:19 PM
by Anonymous User
Not applicable
John Alsup‌ Michael Miller,
Is it a bug or Electric Utility Network Map from the Electric Utility Network Foundation v3.4 solution is not yet updated?
JohnAlsup
Hi mpatilesriaustralia-com-au-esridist , thanks for pointing this out.  There some significant changes to the utility network in 2.6 and we have not yet updated our foundation to include those changes.  However, for now you can just remove the Utility Network Layer from the map and add it back, only it, not all UN layers, and everything should work correctly.
John Alsup
jalsup@esri.com
by Anonymous User
Not applicable
Thanks jalsup-esristaff what about Electric Network Editor Map?
MikeMillerGIS
Esri Frequent Contributor
  • For the publishing map:
    • Remove and add back the UN
    •  Add the Domain and Structure Object Tables
  • For the Editor map
    • Remove and add back the UN from the service
    • No need to add the object tables, unless you added asset groups to them
