@RobertKrisher or @MikeMillerGIS or anyone else in the Community,
We have a Water irrigation Utility Network, which we are attempting to clean up some missing rules which we need to fix some of our network topology errors. Using the Schema owner, connected to the SQL Server, I am attempting to run the Add Rule tool within ArcGIS Pro, and I can't the tool to run or get past this error.
This is within the development environment, which we refreshed from production recently, via the SQL back end. I am connected as the utility network owner (within ArcGIS Enterprise 10.9) running ArcGIS Pro 2.9.5, and network topology disabled.
I made sure all services were stopped, tried it with the edit service running, and nothing gets past it. I get other errors that are more helpful, which lead me to connecting to the enterprise GDB, via the schema owner, which is why I find it weird that it is saying it has to be the owner of a version.
I thought I would try here, before I go to support.
Just wondering if anyone is experiencing the same issue with the add rule tool.
Thanks!
Brian Colson, GISP
