Setting to create pdf feature reports without pdf/a standard turned on
304
03-23-2023 05:03 PM
FayGlunt
Hi.  Is there a setting we can use when creating pdf feature reports that will default the pdf/a standard to off, like it was before last spring?
ZacharySutherby
Hello @FayGlunt
May we ask why the pdf/a output isn't desired? As a workaround you can export the report as a Word document then save the Word document as a PDF without pdf/a compliance.
Thank you,
Zach
