Require user to click URL to continue survey
460
10-02-2024 03:33 PM
Elizabeth_Burniston
In my survey, I have a URL (to the NOAA website) that I want to require users to select prior to the survey continuing. The link is embedded in the text. Is there some 'Relevant' syntax that would make this work? I don't want a "did you click on the link?" - yes or no, sort of question. Unfortunately, we have to force people to look at the weather. Thanks!
ChristopherCounsell
MVP Regular Contributor
ChristopherCounsell
No.
But you could try using pulldata or javascript to put the weather in the survey form directly.
https://community.esri.com/t5/arcgis-survey123-questions/survey123-using-pulldata-to-access-open-wea...
https://community.esri.com/t5/arcgis-survey123-questions/getting-survey123-to-auto-populate-fields-w...
The custom weather example I believe includes NOAA
Elizabeth_Burniston
A user has 3 dates from which they can select starting 24-hrs from now. The day they select has to have wind speeds below a certain parameter. If I can pull wind speeds from the date selected, which seems I would be able to tweak one of the above links, that would work! Thank you for suggesting this Plan B!
