Hello all,
I have a survey form created in Survey123 using Geopoint. To make less effort in preparing offline maps within Survey123, I hope to utilize Field Maps so that field users can download their own offline map areas before going to the field.
This is my workflow.
1. Field users will create a point using Field Maps offline map.
2. point x, y will be calculated in lat and long using Arcade.
3. The value above will be used to create a survey123 url using Arcade.
this is my syntax
<a href="arcgis-survey123://?itemID=...&field:strloss={CIVIC_NUMBER}¢er={expression/expr2},{expression/expr3},20">go to survey123 with XY location</a>
==> here expr2 is lat and expr3 is long.
However, passing x, y point to Geopoint does not see working. Regardless it's done online or offline, it picks up GPS location. Do I miss something?
One of the document by @JamesTedrick shows the parameter as "center:" instead of "center=". I used both but had no luck.
https://community.esri.com/t5/arcgis-survey123-documents/create-survey123-urls-using-arcade/ta-p/100...
Kerry
