Hi, I would like to set constraints to a field to use csv pulldata AND prevent lowercase entry ( regex(., '[A-Z]$') ), but unsure how to do so. I tried putting an 'AND' between the two formulas but it returned an error. Any idea how I can set more than one constraint to a field?
I understand I could use inputmask to prevent lowercase entries, but inputmasks only work on field apps and not in the browser survey pages..
Secondly, I am looking to arrange some select_one questions into grid style so that they are side by side rather than on top of each other, which makes the survey form longer and takes up unnecessary space. The select_one questions need to be autocomplete, so I have the appearance set to autocomplete. But to arrange these into grids I need to enter 'w2' into the appearance column for the same fields as well...which also returns an error when I try 'AND' in between 'autocomplete' and 'w2'. How do I set multiple appearance types to a field?
