Hello! I appreciate your assistance!
I have been tinkering with a custom URL in a pop-up from a point feature service in Field Maps, opening the survey in S123 App. The URL is is partially working - opens the correct survey, and populates in the SITE_NAME field.
arcgis-survey123://?itemID=____________&callback=https://fieldmaps.arcgis.app/itemID=_______________&field:SITE_NAME={FEATURE_ID}&field:center={X_COORD},{Y_COORD}
I have highlighted what isn't working in bold. The callback doesnt work. The center={X_COORD},{Y_COORD} is putting the geopoint at my location instead of using the X_COORD, Y_COORD from the point selected in the map.
When doing initial tests between a webmap and opening the Surve123 in a browser, we had success without any sort of callback. The issues started happening when adjustments were made to the url to use the Field Maps and Survey123 Apps on an Ipad.
Thank you thank you!
Jessica
