allow non survey author to make changes to survey
278
08-25-2017 01:39 PM
Lake_Worth_BeachAdmin
Occasional Contributor III
My colleage created a few surveys and needs my assistance. I cannot seem to find a way to gain access to his surveys in survey123 Connect to use the xls form.
we are both admins in AGOL so I should have access to all his items however survey123 connect will not let me view them. Is this not a feature at the moment?
I really do not want to sit at his machine all day to work on them which will prevent him from getting other work done.
any insight in appreciated.
JamesTedrick
Esri Esteemed Contributor
While you can't view his items via Survey123Connect, you can create a new survey based on his - use 'Create New' and select 'My Organization'.
Ok I did that how do i save it as a new one I do not have that option
