area solar radiation performance
1839
15
03-05-2023 10:51 AM
robertkalasek
New Contributor III
i am working on a intel core i9-13900k machine with 24 cores, 128gb ram and one of the fastests nvme ssds currently existing. and i am about to do some experiments with a test region of about 4000 x 4500 cells 10x10m each.
the expected reuslult set to "Whole year", all the other settings are left default exept for the "Diffusse proportion" - changed from 0.3 to 0.32 and "Transmittivity" from 0.5 to 0.48.
that calculation takes quite a long time and the most annoying thing is, that the taskmanager shows just one single core doing at least something - at an overall cpu workload of 7 - 9% and a rate of about 1,5 to 5.2 GHz.
but on top of that astonishingly poor performance one older machine with lower performance specs in any dimension is outperforming the modern machine by about 30% (!).
DanPatterson
MVP Esteemed Contributor
Yes, it warns you about that in the first paragraph under Usage
Area Solar Radiation (Spatial Analyst)—ArcGIS Pro | Documentation
But did you see the Environment settings that might improve the performance?
Analysis environments and Spatial Analyst—ArcGIS Pro | Documentation
What do you have yours set to?
... sort of retired...
robertkalasek
New Contributor III
thx, of course i have been reading the whole documentation in advance. and i have been experimenting with even smaller (than 4000 x 4000 cells) rasters. especially with the environment parameters for parallel processing - without any significant effect on the performance. and still the first issue is the overall performance of intel's flagship processor but the second is even more concerning - the less advanced machine is on par - both with about 7% workload. which means with more or less just one core working on the calculation job. that concept seems to be pretty outdated to me ... but i am still searching for workarounds and settings to bypass these limitations
DanPatterson
I move the thread to ArcGIS Spatial Analyst Questions
to see if any one from that team knows any specific settings that might be causing the issue
I assume that you have ruled out any dataset specific issues that would affect calculation speed
RyanDeBruyn
Thank you @robertkalasek for your post.
The current solar radiation analysis tools are not designed as multithreaded or honor the parallel processing environment setting.  So yes have their known limitations.
The larger the raster (or greater the input resolution) the longer the processing time and are recommended for smaller landscape scales (less than one degree).
This is something we are actively working on to release new versions of the Solar tools  hopefully in the next release of ArcGIS Pro.   This will include support for larger processing areas, along with performance and algorithm improvements, multithread and GPU support.
We hope to have these new tools in your hands as soon as possible.   In the mean time keep the communication open and let us know any specific questions or issues you have.
Kind regards,
-Ryan DeBruyn
AlbertC
New Contributor II
It's great you are working on it. Please keep us posted!
AlbertC
New Contributor II
Same problem here. We did some calculations back in 2015 for a relatively large area. We worked by iterating an overlapping fishnet of our AOI and it took us about 3 months to process the whole thing.
Now we are doing it again using a new DSM. Our machines are way better now compared to the ones we used in 2015. We are performing first estimates on how long will it take us and it is not much less than 3 months. It's true we have more resolution now (our DSM has 4 times more resolution). But still, one would expect much more improvement having way better CPUs with more threads, cores, RAM, switching from 32 bits to 64, etc.
And yes, you take a look at the taskmanager and it doesn't seem to be doing much, probably uses 5% of resources.
This would be ridiculous in gaming. There have been a lot of improvements in the ESRI ecosystem but geoprocessing power has never been a top priority.
KevinBell1
New Contributor III
I did 800 square miles of Salt Lake County, Utah back in 2013 on 1 meter LiDAR.  Yes, it's a heavy lift.  I ran it for every month of the year on both Direct Hours and kwh/m2, so 24 individual runs.  I was on 32 bit back then, 100 GB RAM, and 32 cores.  That took a month running maxed out!
You CAN run "embarrassingly parallel" but you need a Spatial Analyst license for each core you'll run.  We have a site license, so I'm not limited by SA licenses.  So "embarrassingly parallel" means you write a script for each run, and kick them off separately.  Have the result write to separate file locations and merge afterward.  Done.
GBacon
I'm having better luck with the new Pro 3.2 raster solar radiation tool that can use GPU and parallel processing - I just don't understand the tool parameters and outputs as much as the old one. The .crf output format seems like it has some nice possibilities, especially if I can publish it as an image service.
CPU:
GPU humming along nicely too.
robertkalasek
New Contributor III
@GBacon ... well actually i am not really impressed by an overall 16% utilization-indicator. would be interesting, what the processing-time benefits are. have you tested without parallel processing ?
