Using MapTiles in ArcgGIS Pro
692
11-30-2021 06:34 PM
marienti
I am trying to open the following TMS in arcgis Pro:
http://au.mapspast.org.nz/nzms-1959/${z}/${x}/${y}.png
I have used the 'Add data from path', which brings the Tiled service layer into my project, but it doesn't show on the map window.
I haven't used this feature before, but any help would be greatly appreciated!!!
Thanks Cecilia
ABishop
MVP Regular Contributor
Hello Cecilia,
I clicked on the path you provided and it was a broken link with a 404 error?
Amanda Bishop, GISP
marienti
Hi Amanda, thanks for your reply.
I was following the instructions on this post
https://community.esri.com/t5/arcgis-pro-ideas/add-xyz-tiles-layer-tms/idi-p/940481
where they give the example using
https://tileserver.memomaps.de/tilegen/{level}/{col}/{row}.png
The above link also gives a NOT FOUND error, but ArcGIS Pro still can interpret it and bring it in correctly as a Tiled service layer.
I apologize but I have very little experience with TMS!
Thanks Cecilia
ABishop
I am still unable to add the TMS to my ArcGIS Pro using "add data from path" option.  It throws the following error:
Amanda Bishop, GISP
marienti
Thanks Amanda. I tried the following URL
http://tile.openstreetmap.org/{z}/{x}/{y}.png
and that works OK in my ArcGISPro (even though it doesnt work when you click on it). So then I tried the following
http://au.mapspast.org.nz/nzms-1959/{z}/{x}/{y}.png
But it still doesnt draw any layer on my Map!
