I've created a list of the layers in the map and I'm trying to then use that list to match symbology to a style. Is it possible? When I try I get an error.
import arcpy
import random
from itertools import groupby
from collections import defaultdict
aprx = arcpy.mp.ArcGISProject("CURRENT")
act_map = aprx.activeMap
map1 = aprx.listMaps("Map1")
layer = act_map.listLayers()
lyr_list = []
for position in range(0, len(layer)):
lyr_name = layer[position].name
lyr_list.append(lyr_name)
arcpy.management.MatchLayerSymbologyToAStyle(lyr_list, "$feature.Type", r"\\Path\ArcGIS_Styles.stylx")
File "<string>", line 1, in <module>
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py", line 10200, in MatchLayerSymbologyToAStyle
raise e
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py", line 10197, in MatchLayerSymbologyToAStyle
retval = convertArcObjectToPythonObject(gp.MatchLayerSymbologyToAStyle_management(*gp_fixargs((in_layer, match_values, in_style), True)))
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 512, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
RuntimeError: Object: Error in executing tool
MatchLayerSymbologyToAStyle takes a layer as an input parameter, but you are trying to pass a list of layers into the tool, which will not work. Your MatchLayerSymbologyToAStyle has to be part of your loop.
Additionally, lines 10-14 are not needed. listLayers() gives you everything you need, so constructing a list of layer names is extra work. I would remove lines 10-16 and use this:
layers = act_map.listLayers()
for lyr in layers:
arcpy.management.MatchLayerSymbologyToAStyle("$feature.Type", r"\\Path\ArcGIS_Styles.stylx")
Note, act_map is referring to your current active map in your ArcGIS Pro project. This can sometimes be annoying if you have multiple maps in a project and don't have the right one open. I usually prefer to just define the map by its name. You do that with,
map1 = aprx.listMaps("Map1")But never actually use this variable. If map1 is what you actually want to use, I'd replace act_map with map1.
for lyr in layers:
Thank you!
