I have a problem with the copy parallel command in ArcGIS Pro (2.9 installed version). When I want to copy parallel a polyline which has an arc segment in it, then the arc segment in the copied polyline is reduced to straight segments.
I suspect it has to do with the XY resolutiuon and tolearance of the feature class (polyline features class stored in a file geodatabase), but strange enough I am able to draw a comparable arc segment with the editor itself without the editor converting my arc segment to a line segment.
Anyone else having this problem or a solution to solve it?
Thanks.
