Clearing the cache
15222
10-27-2021 01:17 PM
SLouq
by MVP Regular Contributor
How do you clear the cache in ArcGIS Pro? I am exporting Excel spreadsheets to a folder on a network drive and then bringing the spreadsheet into an ArcGIS Pro map through ArcCatalog. However, whenever I export a new spreadsheet out to the network drive and then bring it into my ArcGIS Pro document it still says it has the same amount of attributes as the last spreadsheet. The only way I can get it to update is if I close the map document and reopen it.
Robert_LeClair
Esri Notable Contributor
Go to the Project tab->Options.  In the Application->Display window, check the box to "clear cache."  You'll need to restart ArcGIS Pro for this to take effect.
Robert_LeClair
DanPatterson
MVP Esteemed Contributor
display cache can be removed here
the cache location is noted there as well
Other case info is in the help topics specific to what you want, or don't want to cache.
For example
How caching works—ArcGIS Pro | Documentation
Clear Workspace Cache (Data Management)—ArcGIS Pro | Documentation
and the list goes on
... sort of retired...
SLouq
Thanks for the replies!
JayantaPoddar
You maybe hitting a known limitation.
"Excel tables are read-only in ArcGIS Pro; however, they can be edited in Excel while you have a worksheet open in the Contents pane (stand-alone table layer). The layer will only display the updated (saved) values for edits made outside of ArcGIS Pro when ArcGIS Pro has been closed and reopened."
Could you try working with a CSV file instead?
Think Location
SLouq
I'll try using the .csv file instead next time. I had had problems bringing csv files into ArcMap way back when, that's why I was converting to Excel.
