It has its limits according to
Mobile geodatabases—ArcGIS Pro | Documentation
and the comment
There are only a few management tasks you perform on mobile geodatabases, including creating, renaming, and moving the geodatabase. Mobile geodatabases do not include authentication or authorization capabilities, are intended for use by one person or app at a time, and support undo and redo when editing. Any operations at the geodatabase level should be performed solely through ArcGIS.
The exclusion of "edit", suggests that those task listed at the geodatabase level are permissable (create, rename, move) and those that aren't listed need to be done by Pro, probably meaning you have to recreate it.
... sort of retired...
