Cannot add field to mobile geodatabase feature class
504
03-17-2023 09:42 AM
jmaxwell_braun
New Contributor III
I get a read only error message when trying to add a new field to feature classes in a mobile geodatabase ("table or feature class corresponding to this view is read only"). I can edit data within the feature classes, but not the data structure (fields, domains, etc). I also tried creating a new mobile geodatabase in a different folder and copying the offending feature class to it. Still couldn't add a new field.
I'm running ArcGIS Pro 3.1.0. I'm assigned a Basic license currently.
Thanks in advance for any suggestions.
DanPatterson
MVP Esteemed Contributor
It has its limits according to
Mobile geodatabases—ArcGIS Pro | Documentation
and the comment
There are only a few management tasks you perform on mobile geodatabases, including creating, renaming, and moving the geodatabase. Mobile geodatabases do not include authentication or authorization capabilities, are intended for use by one person or app at a time, and support undo and redo when editing. Any operations at the geodatabase level should be performed solely through ArcGIS.
The exclusion of "edit", suggests that those task listed at the geodatabase level are permissable (create, rename, move) and those that aren't listed need to be done by Pro, probably meaning you have to recreate it.
... sort of retired...
DanPatterson
and the comment
jmaxwell_braun
New Contributor III
Thanks @DanPatterson. It didn't even occur to me that a limitation for something seemingly simple like this existed. I guess we will hold off on using mGDBs for day to day use.
