ArcGIS Pro Ideas Submission is broken
1776
03-28-2023 02:27 AM
giannalogy
Hi community,
I'd really like to submit an idea on the ArcGIS Pro Ideas board but I literally CANT!
I'm blocked by the required field which doesn't recognize it's filled in. Please halp, this is so frustrating
DanPatterson
MVP Esteemed Contributor
You have selected two labels, pick one, your idea can only go into one location
... sort of retired...
DanPatterson
KoryKramer
Esri Community Moderator
Thanks, @DanPatterson
@giannalogy Dan is correct. Idea submissions in the ArcGIS Pro idea exchange require one single label. Please use https://community.esri.com/t5/arcgis-pro-documents/arcgis-pro-labels/ta-p/1000519 to determine the best label and you'll be able to submit your idea. Thank you!
giannalogy
Thanks @DanPatterson and @KoryKramer
It works with a single label.
