Advanced Editor Tools in ArcGIS Pro
3159
6
06-20-2018 10:15 PM
DaveMarkey
Are the tools available in the editor menu bar in ArcMap available in ArcGIS Pro? I extensively use the various split options, and copy parallel. Or is there another method of dividing a line into equal parts. I also regular use the option to split a line at a defined distance. Is there a way in Pro to copy parallel?
JenniferCadkin
They are available in ArcGIS Pro 2.2 which was just released.
JenniferCadkin
Copy Parallel and Split by Value are available with ArcGIS Pro 2.2
DaveMarkey
Hi Jennifer.
You appear to be getting ArcMap and ArcGIS Pro mixed up. Yes, these are easily available in ArcMap, but apparently not yet in ArcGIS Pro.
JenniferCadkin
DaveMarkey
Goodie. Downloading update now. Thanks for the advice.
DanPatterson_Retired
