XML Workspace - Connect to network location
251
08-12-2022 03:57 PM
Status: Closed
babarsac
New Contributor III
Currently when exporting an XML Workspace that can only be done to the C-drive as per ESRI support. As more organizations move to secure Desktop-as-a-Service (DaaS) and virtualized application delivery not all users will have a traditional C-drive. Allowing ArcGIS Pro to export these files to a shared drive or UNC location would solve this issue.
3 Comments
KoryKramer
That screenshot shows that you're trying to write the xml into a file geodatabase.
I don't see any documented information about the output location being limited to the C: drive. https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/export-xml-workspace-documen...
If you try writing your xml output to a folder on your E drive (not into a file geodatabase) does it work?
babarsac
I actually got it to work after upgrading to the newest version of Pro.
KoryKramer
Status changed to: Closed
Thanks for the follow up. Glad it is working. Closing this idea.
