Hi brains trust. I'm trying to use Arcade to calculate a value in Field Maps based on the intersection of the new point feature with 2 underlying polygons layers.
I've successfully managed to get a value from a field in one layer, but I want it to test it for null values and then return a value from a second layer if null = true.
var BufferedFeature = Buffer($feature, 20, 'meters')
var intersectLayer1 = Intersects(FeatureSetByName($map, 'Layer1'),BufferedFeature)
var intersectLayer2 = Intersects(FeatureSetByName($map, 'Layer2'),BufferedFeature)
for (var f in intersectLayer1){
var name1 = f.Field
for (var f in intersectLayer2){
var name2 = f.Field
IIf(name1=='',name2,name1)
IsEmpty(f.Field)=='true';
return f.Field
return f1.Field
I've tried a few variations of the above codes, and the Field value from Layer 1 returns correctly when it does intersect, but can't get it to return the Field value from Layer 2 when Layer 1 does NOT intersect (and Layer 2 does).
Lindsay Raabe
GIS Officer
Forest Products Commission WA
