Help with returning value from 2 Intersecting Layers with Arcade
715
05-04-2022 10:07 PM
LindsayRaabe_FPCWA
Occasional Contributor III
Hi brains trust. I'm trying to use Arcade to calculate a value in Field Maps based on the intersection of the new point feature with 2 underlying polygons layers.
I've successfully managed to get a value from a field in one layer, but I want it to test it for null values and then return a value from a second layer if null = true.
var BufferedFeature = Buffer($feature, 20, 'meters')
var intersectLayer1 = Intersects(FeatureSetByName($map, 'Layer1'),BufferedFeature)
var intersectLayer2 = Intersects(FeatureSetByName($map, 'Layer2'),BufferedFeature)
for (var f in intersectLayer1){
    var name1 = f.Field
for (var f in intersectLayer2){
    var name2 = f.Field
IIf(name1=='',name2,name1)
    IsEmpty(f.Field)=='true';
            return f.Field
    return f1.Field
I've tried a few variations of the above codes, and the Field value from Layer 1 returns correctly when it does intersect, but can't get it to return the Field value from Layer 2 when Layer 1 does NOT intersect (and Layer 2 does).
Lindsay Raabe
GIS Officer
Forest Products Commission WA
JohannesLindner
MVP Frequent Contributor
Oh, my answer checks if there are any features in intersectLayer1. If you want to check for null values in Field, you can do that like this:
// returns the value of the first non-empty field "Field"
for(var f in intersectLayer1) {
    if(!IsEmpty(f.Field)) {
        return f.Field
for(var f in intersectLayer2) {
        return f.Field
return "nothing found"
Have a great day!
Johannes
JohannesLindner
var featureLayer1 = First(intersectLayer1)
var featureLayer2 = First(intersectLayer2)
if(featureLayer1 != null) {
    return featureLayer1.Field
if(featureLayer2 != null) {
    return featureLayer2.Field
or (same output, a little shorter)
    return f.Field
    return f.Field
Have a great day!
Johannes
JohannesLindner
        return f.Field
        return f.Field
Have a great day!
Johannes
LindsayRaabe_FPCWA
You're a champ! That works perfectly. Thank you muchly.
Lindsay Raabe
GIS Officer
