Duplicate field names Duplicate field names are not allowed ERROR
1206
8
08-14-2023 05:03 PM
ECjin
In order to add this csv item to ArcGIS Online hosted feature layer, I deleted all other feature layers. However, even there has already no layer, the system still display the duplicate filed names error.
JosephRhodes2
Occasional Contributor II
You have two columns named "Total Enrolments_P". (Column F and Column AB).
JosephRhodes2
Make sure you don't have any null fields (empty columns) in the CSV.
ECjin
My data does not contain any null fields or even null values within the cells. They also don't contain spaces.
JosephRhodes2
Are you able to share the CSV?
ECjin
Yes, please find the files attached. Thanks for your help Joseph!
JosephRhodes2
ECjin
Thank you! I went as far as using the ChatGPT Code Interpreter to assess my work, and it didn't flag any issues lol. You spot it! Thanks again!
AsaARevels
Okay what am I missing here I have the same issue as well.
Event_TitleRecovery_Ambasssador(s)LocationPartnersDateAddressCityStateZipcodeApprox_People_ImpactedDecsPhotos        Comments
JosephRhodes2
It's probably all the empty field names. Hard to say without seeing the actual CSV.
