I have some code that will allow a user to geocode two addresses. It will display the points of the addresses on the map.
I want to then set the extent of the map to the two points. To accomplish this I get the x and y coordinates of both points, create a polyline, get and set the extent of the polyline as the new extent of the map.
The problem is that the new extent is zoomed in a bit to far and you have to zoom out one level to see the points.
To get around this i thought I would be able to get the zoom level after the setExtent using the extent-change listener and add one to it to zoom the map out one level.
Problem is if I put the setZoom within the extent-change listener function, the code will get into a loop.
If I put the setZoom outside this function it is undefined.
Specifically the lines starting at 252 are in question.
I am not sure what else I can check or where else I can put the setZoom so that it does not get called until zoom is populated.
var mapMain;
var fromXCoord;
var toXCoord;
var pLine;
var fPoint;
var tPoint;
var fromZone;
var toZone;
var fZone;
var tZone;
var numPass;
require([
"esri/map",
"esri/SpatialReference",
"esri/geometry/webMercatorUtils",
"esri/geometry/Extent",
"esri/InfoTemplate",
"esri/layers/FeatureLayer",
"esri/layers/LabelClass",
"esri/dijit/Scalebar",
"esri/symbols/SimpleFillSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/TextSymbol",
"esri/Color",
"esri/renderers/SimpleRenderer",
"esri/renderers/UniqueValueRenderer",
"esri/dijit/Search",
"esri/graphic",
"esri/geometry/Polyline",
"esri/geometry/Point",
"esri/tasks/query",
"esri/tasks/QueryTask",
"dojo/ready",
"dojo/parser",
"dojo/on",
"dojo/domReady!",
"dojo/promise/all",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dijit/TitlePane",
"dijit/registry"
function(
Map,SpatialReference,webMercatorUtils,Extent,InfoTemplate,FeatureLayer,LabelClass,Scalebar,SimpleFillSymbol,SimpleLineSymbol,SimpleMarkerSymbol,TextSymbol,Color,SimpleRenderer,UniqueValueRenderer,
Search,Graphic,Polyline,Point,Query,QueryTask,
ready, parser, on, all,
BorderContainer, ContentPane, TitlePane, registry
ready(function() {
parser.parse();
var extentInitial = new Extent({
"xmin" : -74.0249340000041,
"ymin" : 42.5025420000134,
"xmax" : -73.5927189999818,
"ymax" : 43.1172190002567,
"spatialReference" : {
"wkid" : 4326
mapMain = new Map("cpCenter", {
basemap : "osm",
extent : extentInitial,
showLabels : true
var albTaxiLayerURL = "http://services2.arcgis.com/A3lMfLhXIUtyxP6p/arcgis/rest/services/CityOfAlbanyTaxi/FeatureServer/0"
var taxiOutFields = ["OBJECTID", "Zone", "Fare"];
var taxiTemplate = new InfoTemplate();
taxiTemplate.setTitle("</br><tr><td><b>Zone: ${Zone}</b></tr></td>");
taxiTemplate.setContent("<tr><b>Fare: $</b><td>${Fare}</td></tr></br>");
var taxiLyr = new FeatureLayer(albTaxiLayerURL, {
infoTemplate : taxiTemplate,
outFields : taxiOutFields,
var defStyle = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_NULL,new Color([0,0,0])),new Color([215,252,216,0.75])
var renderer = new UniqueValueRenderer(defStyle, "Zone");
renderer.addValue("A", new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_NULL,new Color([0,0,0])),new Color([49,70,140, .25])));
renderer.addValue("B", new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_NULL,new Color([0,0,0])),new Color([159,188,245, .25])));
renderer.addValue("C", new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_NULL,new Color([0,0,0])),new Color([135,59,92, .25])));
renderer.addValue("D", new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_NULL,new Color([0,0,0])),new Color([68,135,108, .25])));
renderer.addValue("E", new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_NULL,new Color([0,0,0])),new Color([245,95,235, .25])));
renderer.addValue("F", new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_NULL,new Color([0,0,0])),new Color([227,117,84, .25])));
renderer.addValue("G", new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_NULL,new Color([0,0,0])),new Color([232,245,115, .25])));
renderer.addValue("X", new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,new Color([0,0,0]),.5),new Color([232,245,115, 0])));
taxiLyr.setRenderer(renderer);
var labelColor = new Color("#666");
var zoneLabel = new TextSymbol().setColor(labelColor);
zoneLabel.font.setSize("14pt");
zoneLabel.font.setFamily("arial");
var json = {
"labelExpressionInfo": {"value": "{Zone}"}
var labelClass = new LabelClass(json);
labelClass.symbol = zoneLabel;
taxiLyr.setLabelingInfo([ labelClass ]);
mapMain.addLayer(taxiLyr);
mapMain.centerAndZoom(new Point(-73.769879, 42.662037, new SpatialReference({ wkid: 4326 })), 12);
var scalebar = new Scalebar({
map: mapMain,
scalebarUnit: "dual"
var fromSearch = new Search({
enableLabel: true,
enableInfoWindow: false,
autoNavigate: false,
map: mapMain
fromSearch.startup();
var toSearch = new Search({
enableLabel: true,
map: mapMain
toSearch.startup();
dijit.registry.byId("goButton").on("click", doSearchValue);
function doSearchValue(e) {
var fromAddress = document.getElementById("fromAddr").value
fromGeocodeSymbol = new SimpleMarkerSymbol(
SimpleMarkerSymbol.STYLE_CIRCLE,
20,
new Color([85,82,82, 0.5]),
10
), new Color([76,230,0, 0.9]));
fromSearch.sources[0].highlightSymbol = fromGeocodeSymbol;
fromSearch.search(fromAddress);
var toAddress = document.getElementById("toAddr").value
var toGeocodeSymbol = new SimpleMarkerSymbol(
20,
10
), new Color([245,29,29, 0.9]));
toSearch.sources[0].highlightSymbol = toGeocodeSymbol;
toSearch.search(toAddress);
fromSearch.on('select-result', function(result){
fromWebCoords = webMercatorUtils.webMercatorToGeographic(result.result.feature.geometry);
getCoordsAndZoom(fromWebCoords, "from");
toSearch.on('select-result', function(result){
toWebCoords = webMercatorUtils.webMercatorToGeographic(result.result.feature.geometry);
getCoordsAndZoom(toWebCoords, "to");
function getCoordsAndZoom(geoResults, which){
if(which === "from"){
fromXCoord = geoResults.x;
fromYCoord = geoResults.y;
fPoint = new Point(fromXCoord, fromYCoord, new SpatialReference({ wkid: 4326 }));
}else{
toXCoord = geoResults.x;
toYCoord = geoResults.y;
tPoint = new Point(toXCoord, toYCoord, new SpatialReference({ wkid: 4326 }));
if(fromXCoord && fromYCoord && toXCoord && toYCoord){
var zoom;
var pLine = new Polyline(new SpatialReference({wkid:4326}));
pLine.addPath([[fromXCoord, fromYCoord],[toXCoord, toYCoord]]);
mapMain.setExtent(pLine.getExtent());
mapMain.on('extent-change', function(){
zoom = mapMain.getZoom() + 1;
if (zoom){
mapMain.setZoom(zoom);
