IIS CORS Access-Control-Allow-Origin' header contains multiple values
3641
05-10-2022 05:12 AM
Vakhtang_Zubiashvili
Occasional Contributor III
Hi all,
Again, i am about CORS issue.
I sue IIS for my web map.
So, in my map i sue wms service from another server, that's why i get CORS issue. When i use CORS extension on chrome, i can use this service without problem.
I looked around in google, in stack, but could not find decision of this.
In web.config i have added:
<?xml version="1.0" encoding="utf-8"?>
<configuration>
    <system.webServer>
        <httpProtocol allowKeepAlive="false">
            <customHeaders>
              <clear />
                <add name="Access-Control-Allow-Origin" value="*" />
                <add name="Access-Control-Allow-Methods" value="GET, PUT, POST, DELETE, HEAD, OPTIONS" />
                <add name="Access-Control-Allow-Headers" value="*" />
            </customHeaders>
        </httpProtocol>
    </system.webServer>
</configuration>
but no result, still  Access-Control-Allow-Origin' header contains multiple values.
My map is in Default web Site folder.
I used proxy, but it did  not help.
Any ideas how it could be fixed?
ReneRubalcava
edit - Is this on the server you are trying to get the WMS from?
WMS is outsource, it is on another server and i have no access on it to change CORS options.
ReneRubalcava
Ah, you can't fix this via your server then. The origin server has deliberately disabled CORS or only has certain allows. You can try to write a proxy server for this. The crossorigin.me dev site publishes their source code and you can try to use that as a base for your own. https://github.com/corihudson/crossorigin.me
AdrianaPaese
The CORS extension on Chrome has helped me too. Thank you
