How to get the token for logged-in user in portal ?
1267
09-16-2019 07:40 PM
by Anonymous User
Not applicable
Hi guys,
this might seem trivial but I can't get my head around why IdentityManager's credentials for the logged in user have the token=undefined, though I can clearly see the token in the esri_auth cookie and esri js api is using this token to get access to the portal items... ?
 const portal: esri.Portal = new this.esriModules.Portal({ authMode: 'immediate' });
 portal.load().then(async () => {
     const {username: userId, fullName, email, thumbnailUrl} = portal.user;
     const {token, userId, server} = await this.identityManager.getCredential(portal.url, {
            oAuthPopupConfirmation: false
// everything is populated except the token
// tried all these... no luck
          const val1 = await this.identityManager.checkSignInStatus(portal.url);
          const val2 = await this.identityManager.checkSignInStatus(portal.url + '/sharing');
          const cred1 = await this.identityManager.findCredential(portal.url)
          const cred2 = await this.identityManager.findCredential(portal.url + '/sharing')
          const cred3 = await this.identityManager.findCredential(portal.url + '/sharing/rest')
          const cred4 = await this.identityManager.findCredential(portal.url, userId)
          const cred5 = await this.identityManager.findCredential(portal.url + '/sharing', userId)
          const cred6 = await this.identityManager.findCredential(portal.url + '/sharing/rest', userId)
I'm sure I'm missing something basic....
Thank you!
Tags (1)
Rhys-Donoghue
New Contributor III
hi Michal,
It's a bit late for my reply here but in case you are still trying to do this:
 portal.load().then(async () => { console.log(portal.credential.token); });
Cheers,
Rhys
