I have a basemap with spatial reference wkid 32640, I'm trying to load the basemap which is hosted on our GIS portal using the portal ID as shown in the following code.
I have a normal coordinate taken from google map, which I need to plot on the above mentioned ESRI map.
I have tried to project the google map point to 32640 projection, I was able to project the point but the point / graphic is not getting added/displayed in the map.
require(["esri/Map","esri/views/MapView","esri/WebMap","esri/widgets/BasemapToggle","esri/widgets/Expand","esri/widgets/Locate","esri/widgets/Search","esri/Graphic","esri/layers/GraphicsLayer","esri/widgets/Search/SearchSource","esri/request","esri/tasks/GeometryService","esri/geometry/Point","esri/widgets/BasemapGallery","esri/config","esri/views/SceneView","esri/WebScene","esri/geometry/projection","esri/geometry/SpatialReference","esri/geometry/support/webMercatorUtils"], function (Map, MapView, WebMap, BasemapToggle, Expand, Locate, Search, Graphic, GraphicsLayer, SearchSource, esriRequest, GeometryService, Point, BasemapGallery, esriConfig, SceneView, WebScene, projection,SpatialReference,webMercatorUtils) { esriConfig.portalUrl = "https://server.domain.countrycode/gisportal"var webmap = new WebMap({ portalItem: { id: "fe56448250a*********4637bdbbb1a" }});var outSpatialReference = new SpatialReference({wkid: 32640})var view = new MapView({ container: "viewDiv", map: webmap, zoom:7, spatialReference:outSpatialReference});var point = { type: "point", x: 54.4125, y: 24.4345, spatialReference:new SpatialReference({wkid: 4326})}; var simpleMarkerSymbol = { type: "simple-marker", color: [226, 119, 40], outline: { color: [255, 255, 255], width: 1 }};var graphicsLayer = new GraphicsLayer();map.add(graphicsLayer); projection.load().then(function () { var projectedGeometries = projection.project(point, outSpatialReference); console.log(projectedGeometries.x, projectedGeometries.y); var pointGraphic = new Graphic({ geometry: projectedGeometries, symbol: simpleMarkerSymbol }); graphicsLayer.add(pointGraphic);});});
