Does the Java API support Degrees-Decimal Minutes as an output unit?
3766
02-21-2015 07:57 AM
ThomasColson
MVP Frequent Contributor
Trying to modify a WAB custom coordinate locate widget to show output coordinates in degrees-decimal minutes based on a mouse click event. This works fine, out of the box for DMS and DD, but can't get DDM to work. Units | API Reference | ArcGIS API for JavaScript  seems to indicated that DDM isn't supported, which is quite surprising, as the aviation community uses DDM (which this custom widget is for). Is ESRI dropping support for DDM output, and if so, why?
