Credits (Attribution) not showing in attribution text within map
190
09-13-2024 05:48 AM
ranico
I have updated the "Credits (Attribution)" for some of my layers in ArcGIS Online, but when I toggle them in my map (using the layerlist), they're not showing in the bottom line of attribution text on the map. The base map credits are showing.
It says in the documentation that when referencing a layer item in an ArcGIS portal, the attribution text displayed should come from the Credits (Attribution) property: https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Attribution.html. It should appear in an instance of the Attribution widget in every MapView by default, for example:
Can someone explain why mine might not be showing? I saw another post asking a similar question, and the solution could work for mine, but it is a bit dated and I'm wondering if ESRI has gotten around to fixing this yet or has a better solution: https://community.esri.com/t5/arcgis-javascript-maps-sdk-questions/javascript-api-attribution-widget....
