Adding an attachment with a feature being created
956
03-30-2023 12:34 PM
KyleSchultz1
function saveNewFeature()
var reader = new FileReader();
var file = inputphoto.files[0];
reader.addEventListener('load', function (event) {
var newFeature = ({
attributes: {
"brochure": inputBrochure.value,
"meterNumber": inputmeterNumber.value,
"materialIn": inputmaterialIn.value,
"materialOut": inputmaterialOut.value,
"dateCreated": inputdateCreated.value,
"svNumber": inputsvNumber.value,
"address": selectedFeature.graphic.attributes.USPS_LSN,
"scheduledAppoint": inputscheduledAppoint.value,
"notes": inputnotes.value
geometry: selectedFeature.graphic.geometry,
attachments: [{
contentType: file.type,
data: event.target.result
console.log(newFeature)
globalMaterial.applyEdits({
addFeatures: [newFeature]
}).then(function (results) {
addAttachments: [newFeature]
console.log(results)
reader.readAsArrayBuffer(file);
Forgive me I'm new to arcgis js library. Trying to create a new feature with an existing geometry and attributes. The feature is successfully created but the attachment is left empty. I can add it through AGOL.  Any suggestions?
UndralBatsukh
Hi there,
Setting attachments directly on the Feature/Graphic object does not have attachments property. If your service supports globalIds then you can use the addAttachments parameter on FeatureLayer.applyEdits. The globalIdUsed parameter for applyEdits method has a code snippet for this. I copied and pasted it here just case. You can modify it so that you are creating and adding attachments with one applyEdits.
function addAttachment(selectedFeature) {
  const blob = new Blob(byteArrays, { type: "image/png" });
  addAttachments.push({
    feature: selectedFeature,
    attachment: {
      globalId: "8c4d6085-a33c-42a0-8e11-21e9528bca0d",
      data: blob
  const edits = {
    addAttachments: addAttachments
  const options = {
    // globalIdUsed has to be true when adding, updating or deleting attachments
    globalIdUsed: true,
    rollbackOnFailureEnabled: true
  featureLayer.applyEdits(edits, options).then(function(results) {
    console.log("edits added: ", results);
Or you can use FeatureLayer.addAttachment method to add attachments to your feature. In this case, you will have to create the feature first, get the feature once it is created then call addAttachment method.
Hope this helps,
-Undral
