We have a number of feature services hosted on ArcGIS Server used in mobile workflows. My org is in the process of moving to Field Maps from Collector, and we're running into some issues taking services offline. These services are published from ArcGIS Pro and are configured for traditional versioning, but the server is trying to use the Version Management Capability and failing to create offline replicas.
My understanding is that the Version Management Capability is specific to branch versioning. The option to enable it is greyed out on the feature class in Server Manager, so I do not understand why Field Maps (or ArcGIS Server?) is trying to hit this capability. Has anyone else run into this issue?
Text of error message:
Unable to process request. Error handling schema request: java.lang.Exception: java.io.IOException: Server object extension 'versionmanagementserver' not found.
