Using the logged-in user's identification to automatically filter the map upon its opening
579
5
03-28-2024 04:42 AM
DéveloppeurP
I am developing a custom widget that interacts with a webMap in my organization. My experience is secured with a user group from my organization. My goal is to filter the data on my map according to the logged-in user.
At the moment, I am able to retrieve the authenticated user. However, I am encountering difficulties in using this information to apply a filter to the data displayed when the map opens.
Does anyone have any ideas or has anyone worked on this scenario before?
3 Solutions
JeffreyThompson2
MVP Regular Contributor
The user information can be accessed in a custom widget with the props.user object. So your filter could work something like this.
if (props.user.username === 'Bob') {
    filterFunction()
For an example widget that uses the props.users object, you can look at the Security Widget.
GIS Developer
City of Arlington, Texas
JeffreyThompson2
Can you share more of your code? There isn't enough here to see why you can't connect to the dataSource.
Here is the official sample for filtering a feature layer using it's dataSource.
 https://github.com/Esri/arcgis-experience-builder-sdk-resources/tree/master/widgets/filter-feature-l...
GIS Developer
JeffreyThompson2
The problem line here looks like this one.
const dataSource = dataSourceId && DataSourceManager.getInstance().getDataSource(dataSourceId);
With the && operator, I think this line is only capable of returning a Boolean value. Try taking out the dataSourceId && part.
const dataSource = DataSourceManager.getInstance().getDataSource(dataSourceId);
You might also need to use a shouldComponetUpdate() function to handle the initial load where the dataSource may not be available yet.
https://www.geeksforgeeks.org/what-does-shouldcomponentupdate-do-and-why-is-it-important/#
GIS Developer
JeffreyThompson2
    filterFunction()
GIS Developer
DéveloppeurP
Thank you for your response and your promptness. The issue arises precisely when I try to apply the filter to the datasource :
if (this.props?.user?.username === "user1") {
    this.setState({query : "field = 'dispo'"})
    queryParams = {
      where: this.state.query
    console.log(this.state.query);
console.log(dataSource)
  dataSource?.updateQueryParams(queryParams, this.props.id);
Since it can't retrieve the datasource, it displays "undefined
JeffreyThompson2
GIS Developer
DéveloppeurP
export default class Widget extends React.PureComponent<AllWidgetProps<unknown>,State> {
  constructor(props){
    super(props)
    this.state={filtre: '1=1'}
    this.state={user:'utilisateur'}
    this.state={query:"field = '1=1'"}
componentDidMount() {
  this.setState({ user: this.props.user?.username });
  const dataSourceId = this.props.useDataSources?.[0]?.dataSourceId;
  let queryParams;
    this.setState({query : "field = 'OK'"})
    queryParams = {
  if (!dataSource) {
    console.log("Failed to get dataSource");
  } else {
  render() {
    return (
<div className="widget-starter jimu-widget">
</div>
JeffreyThompson2
GIS Developer
