Filter widgets issue since 1.13 Developer Edition causing troubles in app frontend
249
12-12-2023 02:26 PM
MichalBrodowicz1
Hi, Experience Builder Dev. Edition 1.13 connected to ArcGIS Online.
Something has changed badly in the way filter widget works since version 1.13 of Dev. Edition:
Simple app: points on the map, when point is selected, data from feature layer is shown in text widget and picture widget connected to this dataset.
When nothing is selected on the map, the View for empty selection is shown (configured in Experience Builder Data tab).
There is also a filter widget that enables user to filter points according to their category.
Now, when you select point on the map from category1, and after that, you turn on filter showing only points in category2 on the map, all data inside text widget and picture widget vanishes, leaving horrible raw {data} {references} {looking} {like} {that} while picture widget shows missing image error (cracked image picture).
In version 1.12 and earlier, data of selected feature did not vanish in the exact same situation. What has happened and is there any way to solve it?
