Control divider size of Column/Row/Block widget in ArcGIS Experience Builder
450
09-12-2024 07:59 PM
Status: Open
Labels (2)
MCh
Hello everyone,
I've been stuck with this problem for a while and still couldn't get a solution.
When I try to use Column, Row, or Block which have their own divider inside, I can't control that divider size or number. For example, in the picture below, the Block has 12 dividers and I want to put 3 items inside but there is 2 divider left on the left side and 1 on the right side. This made them unsymmetrical!!
I wish I could control divider number or size. Please consider this enhancement function.
Thank you in advance!
4 Comments
JwHayes
At least an odd number of dividers would help. I've found the dividers are a little larger than I would like in some cases too. This has been an issue for me when designing the mobile version of my app, particularly text behavior in foldable theme header.
NicoleJohnson
I'm not a web developer, but there's something called Bootstrap that's used for the UI, which is where the 12 parts of the row come from (Core concepts | ArcGIS Experience Builder | Esri Developer). My understanding is that it's fundamental and not something Esri can just change.
I think you can accomplish what you want by putting another row into your row, adjusting it, then putting your columns in that:
ShengdiZhang
Currently, we have no plans to add an option to customize the number of dividers in block widgets.
However, you can get a similar look by adjusting the left and right padding of the block widget instead.
Regards,
Shengdi
MCh
@ShengdiZhang That won't help at all. It's just for adjusting the borders and the gaps between items. It has nothing to do with the symmetrical location of all items.
I look forward to hearing good news
Regards,
