ArcGIS Experience Builder Blog
378
5.1M
89
Open | In the Experience Builder Text widget, allow user to create a table to display information. This would not be connect... by LJackson29 Frequent Contributor 1 3 | 1 | 3 | |
Open | I have a custom geoprocessing tool now used in the XB Analysis widget. My tool only accepts a local file upload (CSV ... by mhaley_stone_env Occasional Contributor 0 1 | 0 | 1 | |
Open | When accessing the edit widget within an experience builder application on a windows tablet or mobile device the opti... by BMGIS Emerging Contributor 0 0 | 0 | 0 | |
Open | It's possible to add links to a dynamic/live GeoJSON feed in ArcGIS Online using the Add Layer From URL option. Howev... by TRGTactical Occasional Contributor 1 0 | 1 | 0 | |
Open | When creating a line chart from a feature layer containing a lot of features, only the first 20 are loaded as series... by EviVanTornhout Occasional Contributor 1 0 | 1 | 0 | |
Open | Managing a large number of layers in the Trailing and Leading layer windows is quite challenging. There doesn't appea... by IgorAtamanchuk Occasional Contributor 4 3 | 4 | 3 | |
Open | make it possible to reuse an existing view in different experience builder pages by HélèneETIENNE Emerging Contributor 0 0 | 0 | 0 | |
Open | ensure that view title text returns to the line in view selectors, so that the title is not truncated when the select... by HélèneETIENNE Emerging Contributor 0 0 | 0 | 0 | |
Open | In the Search widget in Experience Builder, the maximum number of results that can be returned is limited to 20. Usin... by SarahNoakes1 Frequent Contributor 8 1 | 8 | 1 | |
Open | I would like colleagues to be able to do heads up digitizing on air photos in EB, then export georeferenced features ... by Pilant_DrewPilant Emerging Contributor 1 0 | 1 | 0 | |
Open | The "Print Widget" in experience builder should offer the ability to set "defaults" for these output parameters:- The... by AustinConklin1 Emerging Contributor 0 0 | 0 | 0 | |
Open | The query widget in experience builder currently has a rest button or cancel option, but can this be made to be autom... by ArronHeriford Occasional Contributor 2 0 | 2 | 0 | |
Already Offered | Similar to the way the Info Summary widget in WAB displayed items, the List widget in ExB should have the ability to ... by AdminAccount2 Frequent Contributor 0 2 | 0 | 2 | |
Open | In the Draw widget it is possible to enable measurement. Unfortunately measurement values show only after a graphic i... by Thomas1 Frequent Contributor 4 2 | 4 | 2 | |
Open | Hey folks!I really like the tool that is outlined in this blog https://community.esri.com/t5/arcgis-dashboards-blog/h... by Daniel_Perkins Regular Contributor 1 0 | 1 | 0 |
Idea Submission Guidelines
User | Count |
15 | |
11 | |
8 | |
8 | |
8 |
