ArcGIS Experience Builder Blog
Latest Activity
(36 Posts)
Jianxia
Adding Experience Builder custom widgets in ArcGIS Enterprise is now supported in ArcGIS Enterprise 11.0 and up. The blog highlights a good level of detail on how to compile a custom widget, register it as an item in the portal, and use it in the app. A special thank to Robert Sheitlint for his Enhanced Locate widget used in the blog as an example.
more
1 1 188
Jianxia
Version 1.9 of ArcGIS Experience Builder developer edition is now available. It picks up features from the June update of the online edition, and allows you to override webpack config and add widget dependencies in your widget folder. See the release blog for more information.
Cheers,
more
1 4 189
Jianxia
Here is a glance of Web AppBuilder widgets migration status at UC 2022.
For a complete and more updated information, see the post of Functionality Matrix Between Web AppBuilder and Experience Builder in the Documentation tab.
more
3 4 499
Jianxia
The June 2022 release is available now! We’ve added three new widgets—PrintTimeline, and 3D Toolbox. In addition, the new Utility service panel allows you to add and manage services that enable printing, geocoding, routing, and more. Other highly anticipated improvements include resetting all filters to their original states, and customizing symbols for the Show on map action. See the blog for more information.
Cheers,
more
0 0 155
Jianxia
Jianxia
A patch is available here for the developer edition 1.8. It addresses an issue that a feature layer from a map service does not respond to the feature filtering or selection. For example, the selected feature on the List widget does not get highlighted on the map, or the Filter widget can no longer filter the data. As this is a regression issue, we would strongly recommend installing the patch if you are using the latest version 1.8 of developer edition.
Here are the steps to install the patch:
  1. Download the repository code and unzip it.
  2. Browse to the patch directory (patches/1.8/patch1/arcgis-experience-builder)
  3. Replace the files in the client folder on your Experience Builder installation with the files from the patch.
  4. Run npm ci in the client folder
  5. Restart the node server in both client and server folders
Let's know if you run into any problems. Thank you.
more
2 1 256
Jianxia
Version 1.8 of ArcGIS Experience Builder developer edition is now available to download. In addition to picking up features from the online edition March update, it improves documentation with a new topic Use data source in widget, and adds a new entry for Calcite components so you can easily import them into custom widgets. See the release blog for more information.
Cheers,
Updated on April 29: A patch for version 1.8 of developer edition addresses a regression issue
more
0 28 1,278
Jianxia
The March release for Experience Builder online edition is now available. It includes five new widgets—DrawDirectionsFloor Filter (beta)Utility Network Trace (beta), and Business Analyst Infographic (beta)  Other highly anticipated enhancements are formatting numbers in expressions, creating two-dimensional grid-style lists, and previewing the page when you are about to print. In addition, the Edit widget is out of beta. For more information, see the blog.
Floor Filter widgetFloor Filter widget
Cheers,
more
1 3 402
Jianxia
A glimpse of new features in the upcoming March update.
more
8 8 1,239
Jianxia
Version 1.7 of the developer edition is now available. Like WAB, you now can import apps and templates from ArcGIS Online or ArcGIS Enterprise to the developer edition or upload them from local zip files. You can also add secured services from multiple portals by registering portals with Client IDs for OAuth authentication. See the blog post for more information.
Cheers,
more
3 1 253
185 Subscribers
