HA: Error in HA plugin. Missing key 'master.node' in the properties file
422
08-21-2023 06:05 AM
RedaAli
Hi Pro,
 I have an error code no:216012 in Highly available 2 Portal machines 10.9.1 on Windows 2019 Env.
However the Properties file that is on \\sharedloc\Portal\Content\items\portal-ha\haconfig.Properties file
has a correct entry for the master.node key which is :
master.node = LocalServer1Name
Kindly, advice.
BenKeller_Esri
Hi @RedaAli ,
Can you check the node.properties file. If it is blank, can you add the master.node and standby.node parameter like it's listed in the master.node file.
RedaAli
Hi @BenKeller_Esri
 Thank you the node.properties file is blank as you refer
 Please let me know where is master.node file located
Do you mean haconfig.properties file as  I didn't find a file named master.node?
if it is Ok please share a content of this file  node.properties file without your site info
