Hi Pro,
I have an error code no:216012 in Highly available 2 Portal machines 10.9.1 on Windows 2019 Env.
HA: Error in HA plugin. Missing key 'master.node' in the properties file
However the Properties file that is on \\sharedloc\Portal\Content\items\portal-ha\haconfig.Properties file
has a correct entry for the master.node key which is :
master.node = LocalServer1Name
Kindly, advice.
